Francis Drake
I have a 2020 F25 Yamaha outboard. It will not start with ignition switch, only start with pull rope. Also, the trim switches on remote and at engine do not work. I can jumper 12v to trim motors and up/down motors are fine. I can jump 12v to starter motor and starter motor works fine. When engine starts, the ignition switch will turn off engine. The remote switches were tested with a meter and all appear to be functioning correctly. The solenoid and trim relay replaced, but no change. What is common to the starting solenoid and trim motors that would disable both? Wiring seems to be okay.
