First Post
Second PCM motor replacement Model 12 653VC, 6.0 450HP in a 2019 Axis A24. Motor developed a ticking sound from somewhere internally, pulled motor and had it torn down to find that the skirt on number three piston had come in contact with the crankshaft due to excessive piston end play. This contact broke a small 1/3" part off skirt and ended up in the bottom of block. Motor had approx 250hrs, oil changed at regular interval, had great compression across all 8 holes otherwise a well maintained 6.0. The motor is just out of warranty by a couple months. The first motor was replaced due to lack of power (took shop 5 months and never figured out why). Over the course of warranty period boat was in the shop several times for various issues with a cumulative time of over a year. Mainly for lack of power, propeller shaft broke (due to internal failure), again lack of power unable to determine why. Motor replaced with a used motor under Warranty though still did not have as much power as new. Any help or advise would be greatly appreciated. Block is still serviceable as well as crankshaft pending further inspection (Magnaflux Crack Inspection)
