2019 Honda 150 goes into limp around 3000 3500 pee water is not worn?
Does it get an engine light on the key switch, horn alarm? if not check your fuel pressure.
If engine consistently runs then cuts after set amount of time or distance repeatable and no alarm then good chance restriction in fuel line or filter. if pressure drops off significantly like below 15 psi, then fuel pump overheating/failing.
