Thank you for your patience as I begin my journey learning about my motor and how to work on it. I still have much to learn.
Currently, I'm dealing with a gasoline leak. Whenever the motor is running and engaged, a significant amount of gasoline is leaking out of a black hose that must be a vent hose normally because it doesn't connect to anything on one end. Below is a picture of the hose and where gasoline is leaking.
This hose travels up behind the fuel filter and connects to something on the top of the motor. Here is a picture of where this hose connects to the motor:
This gasoline leak issue started randomly, and prior to showing these symptoms, the engine would shut off when idling. I would also have to turn the throttle a little bit when starting the motor, as without giving it a little gas, it wouldn't start. Yesterday, I went to start the motor without giving it any extra gas, and it started normally. I went out for a ride and noticed that the engine was running faster and better than normal. Then I smelled the gas and saw that a lot of gas was leaking into the water, so I went home and started my research.
Please let me know if there are any other details I can provide to help with diagnosing this gasoline leak. From my research, it's possible this hose is a vent hose and is connecting to the VST? However, I could be wrong about this.
Any input and assistance you can offer is GREATLY appreciated!
