snirunner24
I have a 20hp Suzuki pull start with around 100 hrs on it. The problem just started back in May and is getting worse. Every 3[SUP]rd[/SUP] or 4[SUP]th[/SUP] time I try to start the motor it takes forever to get it to turn over. About 30 to 40 pulls. Its still under warranty so I will more than likely be taking it in for service. Once its started it sputters a bit and then starts to run normal. I’ve changed the plugs, drained the gas and ran seafoam through it. Ive tried running it out of gas after use and unplugging the fuel line. I’m assuming its an injector problem but not sure. Any info would greatly help thanks.
