Hi all. have a strange issue, changed the oil and lower gear oil on my outboard. On conclusion, the trim will not work, nor will the motor crank. Have carefully looked at all connections/circuit breaks, no loose connections or tripped breakers.
Have done the following:
Verified it is in neutral
Verified the kill switch is in proper position
Verified that nav lights/pumps etc work.
Switched a known good battery for crank motor, no joy.
Trim/tilt was working before changing oil(s)
I am at a loss, what could be causing this issue. All tips appreciated .
Thanks Dan
Thanks Dan
