bass_tracker
Got a problem with a tilt and trim on a 2015 300 hp Suzuki so i change the relay but it didn't fix it... I can put 12 volts on the plug that the tilt and trim button plugs in, and it will go up and down on the two outside wires ... i was thinking that one of the three wires that the tilt and trim button plugs in was supposed to be a hot wire is this right? I 'm not getting voltage on the plug that plugs in the button should i be looking for a bad wire?? any help would be appreciated...
