2015 Honda BF115D
nanserbe
First time poster here.
I have a 2015 Honda BF115D.
During operation, the engine feels like it has a flat spot in the power band when getting up on plane. Probably around 2500-4000rpm If you push past it by accelerating further it smoothes out and cruises fine.
The engine will not turn past 5900rpms, when it has a prop that should allow it to hit the rev limiter. With a 13P prop it should be able to, as a friends same boat and engine will hit it with a 15P or 16P.
The engine also runs rough when it is in gear at idle (650-950rpm).
So far I have replaced both of the small filters under the hood in the plastic cups, replaced the spark plugs with NGK (I may go back to Denso to see if that helps),
There are no warning beeps or MIL lights from what I can tell. The engine has under 200 hours.
