I have a 2015 mercury 30 hp EFI outboard. The engine starts up good when cold, and will run as long as you don't shut it off. When the engine is hot and you try to restart it it will not start, it is not getting fuel as have a fuel pressure gauge on it. When I remove the plug going to the high-pressure fuel pump I have 13 volts when cranking but found that when I plug it in and hook on the wires with my meter as soon as I plug it in the voltage goes to zero as if the computer does not like the ohms resistance of the fuel pump. The resistance does change when the fuel pump warms up, 1.4omhs Cold to .04 hot. I don't know if I have any fault codes, I don't have any way of checking that. So my questions are these,
serial Number 0R668587
What are the parameters that would throw a fault code for the fuel pump and would the fault code prevented engine from running?
If the computer does not like the Ohms measurement it sees on the fuel pump motor will it remove the voltage to it and not allowed to start?
Is there an ohm resistance check I can do to the fuel pump to know that is within spec?
Thank You Tommis
Thank You Tommis
