I have a 2014 50 hp tldi tiller handle and have had numerous instances in which I crank down on the throttle to take off, and the motor hesitates, then slowly dies. I also gave been running wide open when it decides to hesitate, then die. When I try to restart, it revs way high, then dies. It does this over and over but then will finally start normally like it should.
I took it to a Tohatsu dealer last year and he said he ran tests and found nothing wrong. I went ahead and replaced the fuel lines, primer ball, and gas tank, since my tank was from a previous Tohatsu i owned. It ran great for almost a year then started acting up again today. It seems to start giving me fits after I've ran it and it's warmed up. I use fresh fuel, stabile marine additive, vent on tank it open, and plugs are from 2017.
I remember it doing this when it was brand new, but I never took it in and chalked it up to bad fuel from the gas station. It's done this off and on since when I purchased new in 2014 and is still under warranty until September.
My fear is the dealer won't find any issues again and I'll be SOL.
Thanks for any suggestions I can pass along to the mechanic.
