dbieganski
Hello, I have a 2012 40 HP EFI 3 cylinder four stroke that is giving me some grief. It started stalling at the end of last season while on plane. It would start back up and miss a little bit then recover. When it stalled it would give one long beep. I purchased a Rinda Tech Mate and all of the appropriate cables to read the fault codes. I found a Cam/Crank sensor error (M77) in the fault history. I purchased and installed a new crank sensor (the one that reads the teeth on the flywheel) as well as a new timing belt. Yesterday on another test run. I received the same fault and symptoms (M77). The flywheel is in perfect condition as everything else under the hood. I installed new plugs and replaced the fuel line and pump ball from the tank to the engine. I replaced the fuel filter and blew out the fuel line to the filter. Any assistance would be much appreciated.
Thanks,
Dave
Thanks,
Dave
