2012 DT40 "he made me do it" HELP!!!
Whoops my bad
Hi there I have a little issue with my dt40 yes it's my brand spanker!!!!
Whilst I was giving it a flush out my which my two sons were helping with my youngest son decided to pull off the hose, and yes stalled due to overheating and the top piston destroying the bore!!!! Grrrr
he just looked at me pointed to his older brother and said "he made me do it" I had a giggle, till I got the report from the repairer, just wondering if its worth fixing the 40 or if a larger power head will bolt straight on eg 50,60 or anything I can do whilst I pull her down. Any help would be great thanks:)
just go ahead with a rebore and new piston and rings.
while having it bored out you might as well do both cylinders if its a 2 cylinder or all 3 if its 3.
personally i would of wanted to see that engine come apart and see the damage for myself, i wouldnt expect a destroyed bore.
maybe a set of rings needed and a hone but not a destroyed bore, unless you were running this at high throttle for ages.
if it was just idling and for just 5 mins then its not gonna destroy anything.
how long was this running for and at what revs ?
and why wasnt you doing the engine yourself instead of letting the kids do it ?
if they can play around when the engine is running they shouldnt be anywhere near it.
phill
