Crank crank crank nothing...Unplug temp sensor on starboard and it fires right up and runs well. Seems to be rich, re-conencted temp sensor while running tuned off, and it restarts without a problem unless you let the motor sit for 5 mins, then no start.
I replaced both temp sensors and have the same problem. I tested fuel and air, and they are 80 and 90 psi, my cheap gauges bounce but those numbers are the average without fluctuation with engine speed. They lower as the engine sits off. I had the fuel rails apart and both the tracker valve and the fuel diaphragm look good. O rings are good, cleaned the injectors and air injector.
I hear the injectors clicking and the fuel pumps are both on, so something is killing the coils to create no start when the water temp sensor is connected until warm.
Help, the lobsters are calling, mini season is in two days.
