speedyssss
Hoping someone out there might be able to help me. I have a 2011 merc 115 4 stroke. Lately i have a intermittent no power/sputter. Usually it happens mid day. I would go to start the motor after being on the water for a hour or so. It starts fine but when I start to give it gas nothing happens. I could full throttle it and it would not rev. Sometimes you can putter around but you cant get the engine to rev off idle. If I get lucky shut the motor off and retry a couple times and the engine works fine and off I go. Sometimes it happens once a day and sometimes it runs fine all day. Fuel filter and plug basics all done. Thinking possible injector, fuel pump high or low, maybe bad fuel or fuel line. But dont understand why it only seems to happen after I just started the engine. You would think if it was any of the items I mentioned. Then the motor would lose power at various times. Not just after I started the engine. I have car mechanic back ground, but kinda new at outboards. Any help would be appreciated.
