I have a 2010 Mercury 60 that will stall after running at high rpm (~ 5,500). It's as if it has run out of fuel. I throttle back and in most instances it doesn't actually cut off. After I sit for 30 seconds or so idling I can accelerate and will run fine for another 1-2 minutes and will do it again. If I press the primer bulb it'll actually pick back up and run for a few seconds. I connected an external fuel tank,line, & bulb and it did the same thing so that tells me it's not in the boat fuel tank, line, fuel/water separator but under the hood. I've replaced the mechanical fuel pump. Also, it has new fuel filters.
Any help would be great.
