Tom_Alaska
I am trying to find a replacement injector for a Crusader engine. The injector is different that the ones sold as the factory replacement part.
The injector removed from the engine is original equipment, not an after market replacement. I bought the engine new from a dealer, this is the first time an injector was removed from the engine.
Crusader5.7 liter MPI
model number: 50-570-02
serial number: 690285
manufactured: December 2009
The original injector is pictured below. It has the factory paint obscuring any markings on its body. The only identification are numbers on the metal skirt which are 81667 and in much smaller script 0992813392.
The part provided as the replacement is Crusader part number RA087007 and is in the picture with the original injector.
There are several differences in appearance. Placing the RA087007 in the manifold it sits slightly different in height, enough of a difference that the fuel rail will not fit, and the o-ring is too small resulting in a loose fit. It is obvious that this is not the proper replacement injector.
I have run into several dead ends trying to find this replacement. Any help will be appreciated.
