New in 2010 90hp 3 cyl carbied twostroke......started to run a bit rough....done all the usual checks...question.....is the fuel pump supposed to squirt a fine stream into the crankcase of the bottom cylinder when i squeeze the priming bulb? Is this a designed enriching system to aid starting, or have i found the problem? Cannot find any mention of it in owners or service manual.....if it is a design system , how does it shut off once the engine is running? Thanks ........
