smartcar.passion
My 2004 Yamaha 200HP 4 stroke engine won't turnover. I first thought it was the battery but I'm pretty sure now that it's not. I used heavy duty jumper cables from my running truck directly to the outboards starter. the starters gear engages the flywheel but from that point it only clicks. I pulled the spark plugs out of the engine thinking the engine might be seized up and it does exactly the same thing, just clicks...... I can rotate the flywheel easily with my hands when the spark plugs are out so I figure the inners of the engine are fine.
Any thoughts on what the problem might be?
thank you in advance.....
