200hp vro running on 3cylinders
fayter
"I have a unit in here that is
"I have a unit in here that is causing me to pull my hair out. Any assistance will be greatly appreciated.
Engine seems to start fairly easily but is only running on 3 cylinders. Unfortunately two are on one bank and one on the other. Compression is over 100 and pretty even. Spark to all cylinders.
Plugs are not dry in fact fairly oily. I can choke out each carbureator individually and the only rpm drop I get is on the three that are actually running. #1, #2, and #6 OK #3,#4,and #5 problems. If it was all 3 on one side obvious solution. Also with spark tester spark on dead cylinders seems to be intermittent. Oh also tachometer not working will check the rectifier shortly.
Again any suggestions greatly appreciated."
