My 2009 BF225 threw a rod due to water in the cylinder. The rod went through the side of the block. This happened in cylinder #6 at a slow speed right after being on a plane. After some research it seem that if the engine is low in the water then water can back up through the exhaust and cause this problem.
I purchased a factory short block and rebuilt the engine. I also replaced the exhaust manifold on the #6 cylinder side as a precaution. I did not replace or test the heads. All gaskets were replaced.
The rebuilt engine started immediately. While idling with cooling muffs on the trailer (the rebuilt engine has only 10 minutes run time) the engine locked up and has water in the #6 cylinder. There is also water in the intake manifold as seen when the gray intake manifold upper cover was removed.
Very frustrating. Any ideas on where the water is coming from?
