2009 75 4 stroke rpms drop when engine warms up at wot
lannie
"My 5 week old motor with abou
"My 5 week old motor with about 30 hours on it will rev out to 5400-5500rpm 41mph at first, but after 1 hour of driving, tubing, watersking, it will only rev to 5000-5100rpm 35mph. I ve brought it back to dealer they cant do nothing for me. Looking for any advice."
"maybe your boat has a leak an
"maybe your boat has a leak and is taking water ,making it heavier and hence a bit slower??"
Thats good.Id say run the moto
Thats good.Id say run the motor wot when the problem sets in and hit the choke if there is a noticable improvement it is a fuel related issue im taking the easy option first. If not when the problem happens shut the motor down and inspect the plugs you are looking for a wet plug ie one that is not firing .You could also try pulling the plug leads off at idle with an insulated pair of pliers and see if one plug makes no difference to the motors operation .Then you can point your mechanic in a direction .
"Sorry ,been reading without m
"Sorry ,been reading without my glasses again ,damn those 4 strokes.More than likely electrical.motor heats up wires breakes down ."
"Hi there!
If that was my m
"Hi there!
If that was my motor, the dealer would surely be aware of the problem by now.
Personally, I'd not fiddle with anything. If you have, try avoid mentioning this fact to the dealer when you go back...
Good luck and keep us posted.
Chilly regards from a wintery Johannesburg in South Africa.
Benjamin."
"Fair call,however working on
"Fair call,however working on your own boat is very satisfying and with a resource like this page to assist you ,it is a good place to live and learn.The intermittent boat problem can be very exasperating Boat dealers/ mechanics can also vary from very helpfully to looking at you like a dumb ass ,A little fiddle wont hurt."
I have 2008 efi four stroke an
I have 2008 efi four stroke and it acts exactly as you described. but i over look this because of the rough idle and other bad habits.
if you solve problem please inform us of solution. mercury looks at me like i have nothing better to do then talk about this.
