"My nephews Glastron
2008 V
2008 VP 5.0GL - Hard Starting and Stalls when Shifting INTO Gear
Found the Accell pump lever from Throttle Accel Pump Cam to Accel Pump to Be corroded almost fully to shaft, very hard coming off, used 2 1/2"(ish) sized open end/box end wrenchs to PRY off the Shaft, then used light sand paper to clean the shaft and lever hole, works great now."
2008 V
