Totalonenxg
Hey everyone just looking for some opinions on my motor. I just bought a 2009 bass tracker pro team with a 08 50hp 2 stroke. It has a knock I didn’t notice when I purchased the boat. Starts fine runs perfect just has a slight knock at idle and low rpm goes away at 1500-2000 rpm or just can’t hear it. It sounds like it’s comming from the mid section of the motor if I put my stethoscope on the mid section it’s loud. I checked the top end for rod play and piston slap with the wooden down everything seems to be tight to play in the flywheel as i push pull try to get play out of the crank. The motor looks like it’s brand new and very well maintained not a scratch or stain on it looks like a 2016 which I know doesn’t mean alot. I’d say very low hours. I’m just wondering if anyone has an opinion on what it could be. Does it neutral reverse forward doesn’t matter. At mid to full throttle just seems to quiet to be top end. Is there anything in the midsection that could cause a knock. It’s slight not a hammering. And more of a slow knock not racing fast. I also noticed it has a brand new prop and skegs missing a small piece.
