I have a honda BF115 that refuses to start.* Motor has about 50 hours on it.* After sitting for a day, it will start up and run for about 1 or 2 seconds then die.* Never starts up again that day.* Drove it two days before, and it ran fine as usual.* Tried pumping the bulb up until hard, but still doesn't start.* Doesn't sputter, fire*or anything.* Just spins by the starter.* Checked the fuel, clean, checked all filters, clean.* Took it to the local dealer in Fort Worth where it was purchased, and after a week or so, they think it is compression.* They report all cylinders have 115-120 psi.* They said they checked spark and it was good.* They think it is getting fuel because they said the spark plugs looked wet.*
Their diagnosis is that the cylinder walls are scared from sand (or something similar) that got into the intake, and thus the low compression.* They think compression should be 180-200 psi.
I'm having a hard time believing they know what they are doing.* My shade tree diagnosis is no fuel.* Either fuel pump not running or something is blocking it from getting to the injectors.
Any thoughts or help is greatly appreciated.* Does anyone know how to get in touch with a Honda Marine District Service Manager?
Vafite in the DFW area.
