2008 9.9 hp kicker won't idle
dwd1620
2008 9.9 when i put it in idle it will stall out even in neutral? New to boating. someone as told me that i should run the engine out of gas after using it? runs ok at high speeds if i can get it out of idle. Help!
Re: 9.9 kicker won't idle
Despite it only being about 2 years old, it sounds like you have clogged the carb (low speed/idle jet).
And I take it this is a 4 stroke?
If so the good word from the mfg is NOT to run it out of fuel anymore (like Dad did with his) - run stablized fuel ALL the time and leave the carb "wet" between uses...
Yes it is a 4 stroke. will running the stablizer reverse the problem? Or should i try to clean the carb? The big engine runs on the same tank, stablizer is good for it as well?
The stablizer, which is recommended by all mfg's now for all size outboards whether 2 stroke, DFI, EFI or 4 stroke is necessary since most gas contains upto 10% ethanol.
E-10 gas actually burns cleaner and ultimately keeps your fuel system cleaner than gas without ethanol but it has one side-effect - it attracts moisture which can separate out and leave water in your gas, filter, carb etc - no big deal in your car because you burn through the gas quick enough that it doesn't get "old" (takes about 2 weeks), but your outboard could run on the same tank all season depending on usage - plus, some gas always remains in the system somewhere.
So yes, stablizer all the time.
Your kicker may be past the point where something from a bottle will help, but give it a try first anyhow. At worst you are going to have to pull the carb and clean it - which would be the recommended remedy anyhow...
Thank you very much Mr. galamb i appreciate your help in this mater. i should have joined this forum a little sooner!
