whiskeycooker
Motor has been giving me some issues over the past few month when it will not start but when it starts runs fine.
Took it off my lift last week to put on trailer and motor ran horribly. No it will barely run more then a few seconds
I have regapped the plugs and compression tested the cylinders 120-125 on each
Bought a fuel system pressure tester and starts at 5psi then bouches around 35 psi when running then drops back to 5psi when motor insist running so obviously there is a leak somewhere.
Book says it can either be a leaking fuel injector or leaking pressure regulator. My guess it would be on of the injectors since the motor runs like **** even at 35psi but not sure.
Thoughts?
Thoughts?
