Hello all,
A couple months back, I bought a 2008 Mirrocraft troller w/ a 2008 25HP Fourstroke Mercury on it. I don't know how many hours are on the boat, but the motor looked pristine when I bought it and it still does. The boat actually was in my family for a couple of years prior to me buying it, so I had experience with the boat prior to purchasing it. It was treated with care and used on the weekends mainly. I'm the 3rd owner. I don't have any contact with the original owner, so I cant say how he treated it or maintained it, unfortunately.
As of until recently, I don't recall any issues with the motor. Since buying it, I've run into a warning alarm on two separate occasions. Both occasions occurred when I was coming back into the dock to recover the boat, or when I was idling around waiting for others to finish @ the ramp so I could take the boat out. The warning alarm is continuous. No beeping of any kind. The light is on continuously and the alarm chimes continuously. This has never happened to me yet while under full steam, it's always around idle or very slow speed. This is my first boat but I've done some research and it appears this continuous chime is related to either low oil pressure or engine over-heat. I didn't over-rev or over-speed the engine, so that can't be it so I'm leading towards overheating or low oil pressure, or a faulty sensor regarding those two things. When the alarm comes on, sometimes I can kill the motor and restart it after a couple minutes...and the alarm will not sound again. Other times, I can kill it and restart...and it will come back on. But again, this has never happened at full speed or on plane. And it always occurs AFTER I've been out on the water for a few hours fishing, it's never happened immediately after launching. It's always when I'm headed back in after I've fished for a few hours..but then again, it's only happened on two outings so it's not a huge sample size to draw from.
I've read that a good way of diagnosing the issue is to recreate the problem out on the water or w/ a water flusher in the driveway, and then disconnect the water temp sensor, and the oil pressure switch/sensor. One at a time, to see if either will stop the warning chime. I've found the water temp sensor, but I'm having trouble finding the oil pressure switch. I did find what appears to be a sensor about 4 inches UP from the oil filter, it has a rubber cover on it with a single tan/white wire running into it. It's going directly into the block I think. I'm guessing this is it? Is this where you'd also check for oil pressure using an analog gauge? I don't have one on hand, but I can get one and check oil pressure at idle or low speed.
Also, on the front of the engine, there's a removable plastic cover that's shielding a bunch of wiring for various things. On the back of the panel is a wiring diagram. The diagram lists the oil pressure switch as the brown/white wire. All the wires are secured within this management piece. The thing that confuses me though, the brown/white wire isn't connected to anything. It's just secured there and the connector is covered with a protective cover. Is this a separate hook up for an oil pressure gauge maybe? My boat does not have one currently. Or is it possible a previous owner unhooked something and never put it back? So many questions, being a first time boat owner. I would love to get this fixed. Aside from this warning issue that's occurred twice now, the motor seems to be running in top shape. It starts quickly, predictable and idles smoothly.
PS: Oil and Filter were changed immediately after purchasing the boat a couple months ago w/ quicksilver 25w40 and the proper quicksilver filter. I sort of regret not putting in 10w30 BUT I don't intend on running the boat under 40F and according to Mercury, the 25w40 should be fine for anything above 40F temps. Oil level is dead nuts. Not under filled or over-filled. I put in exactly what it calls for, minus any minor spillage that could've occurred during the change.
PSPS: I can provide pictures if requested. Again, thanks for any help in advance.
