88maverick
2008 Etec 150 hp with nearly 800 hrs. New dealer installed water pump/thermostat. BTW-- best motor I've ever owned.
After arriving at the fishing grounds (15-mile trip), if I let the motor idle (tach shows 500 rpms, water pressure gauge about 10 pounds) for about 15 seconds, the water pressure gauge will oscillate for about a couple seconds and then go directly to 0 pounds pressure and the engine temp gauge will (obviously) immediately climb. At first I thought this was a bit of grass or something blocking the water intake, but it was clear. If I increased the idle to only about 650 rpms, the water pressure rises to about 12 pounds psi and the temp stays cool.
For the past week, this same things has happened the same way. If the engine is cold, this does not happen. I'm stumped and apparently so is the mechanic. I suspect some sort of improper installation of the water pump, but need advice. HELP GREATLY APPRECIATED.
