The engine Is a 2007 4 stroke. Stored for a year. Both cylinders firing. Model “F15”2 stroke or 4 stroke ----Model # is ?------Have you confirmed spark on both cylinders ?------Did problem develop suddenly ?----How did it run for you last week ?
It has always run fine. Prime start and jets are operational. Starts and idles fine. Runs smooth up to 3/4 throttle. No top end.I am not there to help you / prod you with your work.-----I would say a blockage in the carburetor or a compression issue.---Are the valves moving ?-----How did it run for you before you stored it for a year ?
Why the reluctance to provide the model identity? Is the motor "hot"?
What country are you in? Here in the USA there were five different F15XXXX models offered. F15CELH, F15CESH, F15CMLH, F15CMSH and F15CPLH.
Is your motor one of these five? If so, which one?
The more information that you can provide the better the answer(s) you will receive. Otherwise everyone is left having to guess.
