Hi all,
This is my first post Been lurking here for years. Always found my answers and tips till now in previous posts. Anyway just got a new to me boat with the above motor. Boat has set for a few years. The guy sayed it needed a water pump impeller. Sure enuff it does. I have replaced these before on evenrodes and johnsons. even a suzuki. So i figured this one was no problem either. I took the pin out of the shift rod, took 4 nuts off the lower unit studs. Did the knock the lower fin to the side and nothing. I have done everything but blow it up and still will not seperate. checked for hiden bolts and found nothing. So my big question is what am i missing or is it just stuck solid from setting? can i drive something thin between the 2. (scared to do that) I did beat on it with a rubber mallet. Put some penitrating oil on the studs. Still stuck? Help please
