Calabashman
Today my engine began running very rough with hesitation, lost rmps etc. I started checking ignition areas.
1. checked all plugs and they all looked the same & ok (and are only a few hours old.)
2. With engine running I disconnected 1 plug at a time expecting to see/ hear performance loss etc. - which I did for all cylinders except the very top cylinder. After 2 tests there was no decernable change in engine performance.
3. Attempting to eliminate 1 problem area I swapped plugs 1 & 2 and retested. No change in performance again in cylinder # 1 with # 2 plug in place. That eliminated a problem with the plugs I feel. That's where I'm at now and hope to get advice as to what I should check next. Oh yes I did try 1 other test. With the engine running +- 900 rpms I pulled out the engines manual choke which seems to smooth the engine out some but not a lot. Acceleration performance and lost rpms didn't change.
Thanks, any help will be appreciated. Calabashman
