ChrisSupple
I need help with this one! Engine cuts off when I shift from “in gear” to neutral. It happens every time. It doesn’t seem to make a difference whether I’m shifting from forward or reverse into neutral. Obviously, this is a problem when trying to dock or put on the trailer. It will restart in neutral & idles fine. It doesn’t cut off when I shift from neutral into gear (F/R). Otherwise, it runs fine at any speed. I would think the idle is too low, if it cut off when shifting from neutral into gear, but my problem is just the opposite! Any thoughts or suggestions? Thank you in advance!!!
