Hi,
I have a 2007 - 30HP - 2 Stroke Mariner on a 399 Stacer Proline Hull.
I took the boat out for my first test run and i was running it on and off for about 3 hours, cruising for 10 minutes at a time in between spots.
After a few hours i decided to head to the top of the creek, so i was running at WOT for about 15 minutes when the motor seemed to mis-fire or have some kind of issue resulting in the motor cutting out (Large vibration and the motor kicked/wobbled too)
I could not get the motor to start again (Coasted to ramp with Minn-Kota)
When i got home i drained the fuel (95 Octane from Caltex) and replaced it with stock standard 91 Unleaded with new oil - I also drained the Carb and removed the old 95 from the other hoses and gave it new spark plugs.
I can start the motor again and it Idles but the revs appear to drop and then come back.
I have cleaned the Carb and it seems immaculate, all the jets and needles are cleaned too.
The IDLE is set on the Carb correctly from what i know as when its running well there are no problems, its the drops in RPM that have me questioning the motor.
Either i assume its ok and take it out again or i book it into a boat mechanic to pay out the butt for a look over - I dont know if im just over thinking it or not.
It is hard to start as well - i hope the running-videos may help someone determine if it sounds ok.
The only strange thing i can notice is that the roller-cam that actuates the arm on the carbie has been wrapped in electrical tape to increase the the the WOT top speed - If i remove that tape the boat only does 28-30kph - with the tape it does 42kph
(The tape just seems to help push it slightly further to the WOT position)
Tests/Info/Video Below:
https://www.youtube.com/watch?v=IaxSNOVYgCY - Idle Video showing RPM Drop
https://www.youtube.com/watch?v=fXQUnTor_Ao - Video of 2 minutes of running with revving etc
Cylinder PSI:
Cyl1 = 155 PSI
Cyl2 = 160 PSI
New Spark Plugs BR7HS-10
Cleaned Carbs/Jets
Cleaned/Replaced Fuel Filter
Replaced Fuel Hoses
Cylinder PSI:
Cyl1 = 155 PSI
Cyl2 = 160 PSI
Cleaned Carbs/Jets
Replaced Fuel Hoses
