2007 225 optimax upgrade
jwe2
"i have a 2007 225 optimax, is
"i have a 2007 225 optimax, is it possible to upgrade this motor to a pro xs, looking at the specs, the bore is the same as the 250 only the rpms are different"
"Johnny, normally the only dif
"Johnny, normally the only difference is the ECM (engine computer).
However, that is a 2000 dollar component. Now if you think an extra 25 horses which will not produce any noticable performance difference on your motor is worth 2 grand, it could be a simple change.
However, if you happen to live in the US, it is illegal to alter the horsepower of your motor...."
"Graham is right .For my 2 cen
"Graham is right .For my 2 cents worth .if you dont alread id buy a go fast prop and jack plate it would get you more mph
"thxs guys, i run the boat at
"thxs guys, i run the boat at 6000' altitude and wanted to improve the hole shot, i have a jack plate, still working on the prop for hole shot and top end, 23 pitch is pretty good for my self, but my fishing buddy is good size and with water in live wells, may have to drop to a 21,"
The XS has different reeds and
The XS has different reeds and rail pressures.
The computer is aware of the altitude via the MAP sensor. The L/U gear ratio may be able to be lowered a little to make you for power you lost. That is usually what you do to fix that.
