Hello;
My 2007 Optimax 175 was slow to start a couple of times and now won't start at all. Dribbling gas into the induction system causes it to start and run until it runs out of that gas. So, some of the PCM is active.
Each injector (6 fuel and 6 air) has two wires. It's my understanding that the injectors are supplied with ~12V via one wire and the other wire goes to ground via a 'switch' in the PCM.
It appears all of the injectors are seeing random voltages of less than 1. One wire is, indeed, a low impedance switched lead to ground, the other wire shows, basically, nothing.
I can't find a wiring diagram for this exact model. Similar ones all show both injector wires coming directly from the PCM.
The PCM is getting battery voltage when the ignition is on.
Can we conclude that the PCM is not functioning, or is there a wiring diagram showing something different?
Thanks in advance for any thoughts.
