mercury_rookie
2007 15 hp mercury 4 stroke won't idle SN#1B501908
starts ok
fuel/plugs/fuel filter replaced/using fuel stabilizer
when you decrease the throttle it dies fairly fast
also today while pumping up the fuel line bulb and trying it out after replacing the fuel filter it leaked a fair amount at the base of the carburetor although this stopped after I started it up for a while and I couldn't reproduce the leak when the engine was hot
I guess I need to know if I should rebuilt the carburetor at this point or any other suggestions.
I have been running the fuel out after every time I don't use the boat for several days and just read a post that said it may cause the same problem I am describing, any thoughts?
starts ok
