HI everyone- I hope you had a nice thanksgiving. I have a 2007 optimax 115- which is literally a new motor and boat. My brother and I bought it new in 2007 and he died 3 months later- we used in one time for about 30 minutes (then it got dark)---it was after we picked it up from cabelas. Anyway- his estate was in probate, and his girlfriend tried to get the boat, so thankfully, my dad- the admin- had it stored (covered) and shrinkwrapped and had the motor serviced and started several times a year- and serviced annually. When I got it this year, I cleaned it up, and my wife and I went to the lake---the same one ironically we went to when we got the boat. It ran perfectly but someone had messed up the prop---not rocks- but where the exhaust comes out it was bent- so I bought a new one. Its ran flawlessly all year. I recently changed the plugs and found some autolite irridiums on sale- and bought them, put a new fuel and air filter in, greased it, changed lower unit oil and impeller. We went to the lake and it wont idle but runs perfect WOT. I came home and thought - its those plugs. I bought some ngk (spec plugs)- and same exact thing. I checked the fuel filter---to see if there was gunk in the bottom- (from the fuel lines) no. So I am wondering if I have some bad fuel- 26 gallons of it. I might siphon it into my cars and refill the boat up with premium. I always run star-tron- and have never had issues in many many years. I guess the next step is to check the air/fuel pressure- and see if I have 10psi difference, and beyond that- I am confused- unless its an injector or some other issue. Does anyone have any ideas? I worked at an evinrude dealer for a few years doing service- I am not completely naive about servicing motors and I have the (genuine) mercury service manual. Everything I do is done to specs---torqued properly, proper supplies- grease oil etc- the only time I have deviated is on those autolite plugs- and that doesnt appear to be the problem.
Is this an optimax problem? There seems to be many that have idle problems at one time or another. If all else fails I will find a mercury service center here in phoenix. Thanks
