bombardrib
2006 25hp 4stroke fuel injected Tohatsu. Motor has only @8 hrs. I last cranked it @ 9 months ago with no problems. I cannot crank now. Have cleaned fuel tank replaced fuel line and cleaned one fuel filter. Engine turns over well with good spark. I removed the vapor separator and pulled the fuel feed pump. I applied 12VDC to pump and could not really tell if pump was working or not. I filled the vapor separator housing with new fuel and reassembled. The engine ran for @ 3-4 minutes then shut down. How can I tell if fuel feed pump is defective?
