Snakeriversailor77
I'm trying to diagnose a problem that is frustrating me. I've looked at the other posts on this and it's not quite the same as mine so sheer it is. The engine reservoir is not refilling from the secondary reservoir. Seems like a pump or line clog. Checking the pump and passing the wiring to it gets it to in but doesn't seem to pump any oil. The emergency switch to fill the reservoir doesn't activate the pump at all. Continuity in the line from the engine to the oil pump reservoir but doesn't seem to have any power to the cable in the first place. Doesn't send any signal at ignition on not running or running. The engine resevoir is down to the low mark and alarm is on. Float switch in engine resevoir has been replaced. Might be a clogged line but why no power and why isn't the pump running? Taking the boat resevoir tank out today to checked or sludge and or kinks. What else?
