jcastellucciojr
After changing out the Racor water-separator filter and the in-line fuel filter under the cowling...ran the engine on the muffs for about 10 minutes...checked for fuel leak. Good water flow from pee-hole and thru hub exhaust. Upon removing the muffs, happened to touch the housing just above the cavitation plate (where the plastic nut insert for the anode is located)-almost too hot to hold onto. I have never had the occasion to touch that area after running on the muffs...IS THIS NORMAL??? Thanking you in advance...John Castelluccio, Jr. Southeast Louisiana---Lower Bayou State
