heritage2008
So I have a MFS4B and since the outlet from the internal tank broke off (Previous owner didn't want to mess with it) I decided since I had an 8hp and 20 hp Tohatsu already I'd just plug in one of my tanks--yes, the 4hp has the male fitting already--but was leaking so installed a new one. I by passed the petcock and removed the drain back valve (looks like a larger Merc filter) and ran a hose from male fitting to a fuel filter then to the fuel pump. This motor Sat on it's wrong side for sometime (thank you PO) so I pulled the plug and pulled multiple times to clear oil--nothing came out. Motor wasn't used for sometime before I picked it up.
So changed oil and lower unit.
Motor fires on first pull while choked but when I try to push choke in slowly it dies--revs really high while on choke. I get the choke 75% in and it just gives up.
Pulled carb-soaked,, sprayed, checked float etc and had the 3 new gaskets. Repeat-does the same.
Already put in new plug when I changed oil.
Pulled fuel pump-cleaned and put back--not sure if diaphragm is good.....Put back on.....same result.
Fuel flows freely through the pump to carb when bulb is pushed so fuel is getting through.
When I started the engine and had the hose from pump to carb off--the flow was just a spit--hardly any came out--yes line and filter was full and under pressure.
The tank and line maintain pressure and the tank is vented.
So-----did the fuel pump take a crap?
