Hello,
I have an ongoing problem with my MCM MX 6.2 MPI. It starts perfectly cold, then runs perfectly but when shut off it does not fire back up. It will turn over and get a couple cylinders to pop but will not fire up. If I give it nearly full throttle, it will fire but after a lot of turning over and just barely make it. If it gets close to firing and I stop, it flat out will not start unless I wait an hour or so. One thing I have noticed is that if I run it, then put the boat on the trailer, take it home and fire it up about 30 minutes later on a hose, it will fire up normally even though given the same circumstances with the boat staying in the water it would not have. This issue has stumped the mechanic that works on it. So far the following has been done to the motor: Replaced entire fuel pump assembly- which by the way does not warm up when running. The injectors have been cleaned up and are up to spec. The Idle air control valve has been replaced. The throttle body has been replaced. The Mapt sensor has been replaced. The Crank position sensor has been replaced, the fuel regulator has been replaced and lastly the throttle position sensor has been replaced. Quite frankly I am running out of money and Ideas to toss at the motor. Does any body have any guesses as to what else could cause this hot start issue or any test that I can preform to check?
Thank you,
Randy
Thank you,
Randy
