2006 merc 8 hp 4 stroke shift linkage problem
R
robert kardonis
Guest
"I use the above motor as a ki
"I use the above motor as a kicker. Problem is that when I put in nuetral to start, I cannot pull the cord because the mechanism remains locked as if it is in gear. It looks like I need to tighten or loosen the cable, but I'm not sure how to do it. The dealer fixed it a couple weeks ago, but now it is malfunctioning again. To start it, I have to remove the cover and manually hold it in unlocked position. Any help would be appreciated. Thanks Bob."
Apparently this one is a real
Apparently this one is a real stumper..any ideas?
