drumfishcommander
I have a problem that has been going on for a couple of years now on and off. The noise happens on a cold engine when I give it some rpm's backing off of trailer an when I go to neutral it sound like a loud grinding and scraping noise. When I put it in gear it goes away. After it warms up a bit it stops. I have had it in shop 3 different times.Thought it might be shaft bushing but that is ok. after pulling the lower unit 3 times i have determined that the noise is coming from the top of the lower unit shaft right below the spline that connects to fly wheel.Removed starter to look at fly wheel. That looks good no corrosion.I did start engine without lower unit to make sure noise was coming from lower unit. last time I put omc tacky grease at top of shaft seems to help.
