Last fall I changed the outdrive gear oil and used the merc HP gear oil ... stored the drive in the down position inside on concrete found gear oil leaked out over the winter... filled the bottle, de winterixed ran on muffs put is back in the garage for 2 weeks with the drive down no leaks were found
estimate 6 oz had leaked over the winter
No water was evident in the old oil....Drive had been serviced in july with a replacement cone clutch so it has been recently removed/resealed
Do I need to be concerned?
whats the opinion on drive showers? Do have some chalky on the upper drive not alot buts it always been there/
