2006 75hj Optimax Won't Start
goinstrong
Hi folks...My 75 hp 2 stroke Optimax won't start...I had a problem with the cooling system being plugged and got that cleared...During the process I stupidly hit the air valves on the fuel system...Now it won't start...Any ideas?
Pray?
Seriously, these are so complex that you can't fiddle with a multi-meter and a screwdriver and hope to figure anything out. You need to get her "plugged in" to see what's up.
If your battery is fully charged and you have her hooked to a tank full of gas that's about the extent of troubleshooting the average guy can do in his driveway.
I work on Mercs but don't have a DDT, so aside from changing an impeller, filter and plugs, Opti's (and most 4 strokes) get directed to the authorized Merc dealer across the street from me...
Do you mean they you damaged the air port where you check the air pressure?
Well guys I appreciate the responses...I have discovered that the low pressure pump is bad and decided that taking it to the experts is the best way to go...Thanks for the tip docksidemarineservices...
