Mrtruesdell
The engine had been running good on my first trip with it. Second trip I had a pick up tube in the external gas tank on a pontoon go bad I replace the tank, Bulb,fuel line. It had a 30 amp fuse burnt bad up into the socket. I replaced The wire and put a 25 amp back. Checked all other five fuses and they were all good that I found. Now getting fuel up to the filter which I also replace the filter but only a little fire but not all the time like it wants to fire off but something is still not working. My ignition switch on the pontoon says push to choke but ignition switch not pushing in or stuck in don’t know if this could be the problem. The motor also does not say mariner it only says mercury.Thanks John
