scoopup928
My engine cranks, idles and runs fine until 3200 rpm or 2700 rpm under load. At that point I can give it WOT and want get above those rpms. I have replaced the fuel filters, Distributor cap rotor and spark pugs with no change. The boat stays in the water 24/7. Even though I have bottom paint I have to pull it out and clean the prop and outdrive every couple of months In the summer. I assume the exhaust goes thru the outdrive. Is it be possible it is clogged and blocking the exhaust? Any suggestions are welcome.
Thanks,
Thanks,
