I have a knock issue when my 2005 225 Yamaha engine is running. I removed all spark plugs, turn the flywheel by hand and as l turn the flywheel it gets stuck at the same point of a full rotation. I apply heavy pressure at the stuck point and it bumps over what seems like an obstruction somewhere under the flywheel. Has anyone ever experienced a bad flywheel or stator which can cause such an issue?
I have checked compression, all good. Static water test thru water tube (lower unit removed) no water coming out of exhaust port.
I cannot find any posts which relate to a broken stator or loose magnets on a flywheel (not sure if this engine has magnets on flywheel).
Any help would be greatly appreciated.
