Thanks racerone. Load test was fine, but the 20 amp fuse in the motor wiring harness by the starter was blown. I changed it, then both the motor and trim worked. Now I just have to figure out why it's not smoking. It set up a while. Both reservoirs are full with two cycle oil. I ran it for a couple of minutes, noticed it wasn't smoking like it used to, and shut it down for fear of damaging it. Should I try adding some oil to the fuel tank? I put ten gallons of gasoline in it after draining the old gasoline and changing the fuel filter.Checked fuses ?----Have battery load tested.
